A customer has low v. lighting in her bathroom. Four of the lights were out. So I took one of the bulbs out and ohmed it out. It rang out. So the bulb is good right? Took a bulb from a existing one that worked, stuck it in and presto it worked. The bulb that wouldn't work said 12volt 50 watt. The one that did work said 12volt but I couldn't read the watts. So is the reason why the first bulb wouldn't work, because the wattage is to high? Or is ohming it out not telling me everything? P.S. Also the customer said they worked for a week or two, before they stopped working. Thank you for your help.
