1.) How do you know when to use 3/C or 1/C? For some applications if space isn't an issue and it's cheaper to buy say two 1/0 1/C and a ground instead of a 1/0 3/C can you do that? Is the conduit fill the same for say 1/0 1/C and 1/0 3/C?
2.) How do I know whether I need shielded or unshielded cable?
3.) When doing voltage calcs using the equation CM = (2 x K x I x Distance) / Voltage. How do you know what voltage value to use say for 120/240 supply if your device is using 120 volts? Is it 120 Volts for the device or is it 240 Volts for the supply?
4.) Do I always run a ground wire no matter what the device is?
5.) Say I have a breaker panel that cannot fit 2 parallel 4/0 cables so I have to use a junction box to make the cable smaller before going into the breaker panel. The 2 parallel 4/0 cables would be an upgraded size to keep VD under 3% for a device over say a 1500ft run. How exactly is that wired in a Junction box?
