- Chapel Hill, NC
- Retired Electrical Contractor
I think the misunderstanding stems from the OP's install being called a Calif. 3 way.  It is not, IMO.
	This is what I call a Cali3Way.
The better way to look at it is that there is no article that makes it illegal for NM wiring methods.What art in the 08 code makes this legal with nm cable
Looked at an existing home (brother-in-laws) and found that the 3 way switch in the dining room only has 2-wire running from 3-way to 3-way. Have not found where the switched leg is being picked up for the receptacles in the room. I have always seen 3-wire to carry current over the "travelers" between switches, then to the fixture on the common leg. Anyone have any thoughts on how this was installed. Never seen before and have not figured out yet. Gong back tonight to open up more boxes. All this work to install an overhead light for the dining room.
Try article 300.3(B)(3)What art in the 08 code makes this legal with nm cable
At least this is better than switching polarity on the duplex.This is what I call a Cali3Way.
Wouldn't this be a violation because half the time the bulb socket would be reverse polarity. In the even someone decided to change the light bulb when it was on, and the normal neutral was hot the person more easily come in contact with the threaded hub portion of the socket which would normally be a neutral. Just a thought.
Roger
