Controls Guy
- Central PA
I have been using meggers for well over 25 years. Having an aviation background before switching to industrial in 1997, 100 MegOhms was accepted as "good" when testing aircraft wiring to ground.
The 100 MegOhm or above rule has served me well to date.
I have recently come across a situation with extremely long 480 3 phase runs - > 2000 feet measuring low phase to phase and phase to ground. The feeders are underground, with vaults and conduit extremely wet and even submerged because of the water table.
Readings vary from >4000 Megs down to tens of thousand of ohms. Megger results are consistent on 500 and 1000 volt tests. With my background in aviation and the 100 MegOhm go/no-go rule, this has worked for 25 years.
However, given I have not yet had to address such a bizzarre underground installation before, this old dog needs to learn some new tricks from someone that has an extensive background with underground feeders.
Any feedback would be greatly appreciated!
