BretHeilig
- Brooklyn NY
I'm trying to propose a commercial PV array that will be intertied to a 120/208Y service. There is only enough room for about 7kw worth of modules, however, which means I have to go with an inverter that only outputs to 2 of the 3 phases. The inverter does have a neutral.
I understand how load-balancing works with a split-phase system (worst-case scenario, the neutral is carrying all the return current), but I don't really get how the concept applies to a three-phase system. Is this something I just shouldn't do? Or is there some rule I can follow ("keep the neutral the same size as the hots") or some existing condition I need to verify, which will make this okay?
Thanks for any advice, or links to explanations
Bret
Bret
