Feed from motor controller to sewage grinder pump
ivsenroute
Florida
Like I wasn't going to lift the rock at the base of the conduit when i saw the bell right at grade.
Forgot to add that the pump is about 20 feet away and the cable is just as shallow the entire way until about 3' away from the pump.
Yep their about 18" to shallow. Can't get nothing past you.
That SO is exspensive they should have used uf . Or thhn /w in conduit.
I can't believe someone would call in for inspection on something like that.:roll: Is this a homeowner or EC install? I'm honestly surprised they even pulled a permit...
This is brand new construction with an EC. Welcome to the Poconos
