Switchboard Weight
Keri_WW
Anyone know how much 3-section switchboards weigh?
1600A GFI MCB, 480V, with SPD
Thanks!
Keri :grin::grin:
you mean 1600a with GFP ?
Yes! Only issue with contacting the manufacturer is that I don't know the actual equipment that is going to be purchased and used. I was looking for a rough estimate if anyone knew it off the top of their head.
Hard to tell you what something weighs if you don't know what it is, how about heavier than a squirrel and lighter than an elephant.
The breaker alone will be 200-300 lbs, the gear and buswork another 500 or so, but you need more details for any estimate of any value.
Enclosure type? Accessories? Just the 1600A breaker? Cable in/out or bussed? Etc......
Are you concerned about putting this weight on a wooden floor ?
Or on a wooden floor on the second floor, if thats the case then someone needs to get a structural engineer involved.
You could get your concrete apron poured specific with a higher PSI then the surrounding aprons.
Seems there's more to the question, but I always ask fifty questions any was, I don't usually type them out :grin:
