lowvoltman
If you had a 480/240-120v single phase transformer with primary taps set at 480v but were only receiving 422 volts, what would the secondary voltage be? 105v?.  If you changed the tap to 432v(low as it goes) what would the secondary voltage be then? 117v? Is my math correct? thanks.
