- New Jersey
- Journeyman Electrician
The 3rd screw is the one loose in the inspector's head.
Agreed.
______
I worked for several contractors and we always used 3 screws. With todays screwguns how much extra time would it take?
Exploding Head SyndromeUgh. Not the point here. :roll:
If the studs are wood I usually use staples to bang 'em up. Inspector cuckoos head would probably explode.
Is the AHJ citing the '05 or '08 NFPA 70?
Either way, 314.23 [1] says nothing about 'how many' fasteners are to be used.
I could understand him if, say, you used only one nail or screw... or if the surface isn't rigid or there isn't secure enough support.
This will be an interesting outcome.
I think your mistake was letting him cite you without a code reference. "I'll get back to you" doesn't cut it and is unprofessional IMO. If he can't cite the code he thinks your violating right then and there, he should schedule another inspection when he does know the code or else he'll be forced to pass you. It's not your fault he doesn't know the code and on top of that you shouldn't have to suffer the consequences of holding up the project while he tries to figure it out. Just my opinion, of course. Maybe you could try his supervisor...
For the record, I use two 10x3/4" or 1" screws to hold boxes to wood studs all the time.
I wasn't there when he inspected. I called him on the phone when I got the word it failed. I have already called for reinspection. However, they're off tomorrow and mon. So it will all come to a boil on tues when hee sees I did not put his imaginary third screw in. It should be an interesting morning.
Arrgh!! We gotta wait five whole days?! The agony!!... they're off tomorrow and mon. So it will all come to a boil on tues ...
So he's coming back to reinpect for other reasons, or is the alledged 3-screw rule the only obstacle?
I did ask him was that a local code,,,,he said no,,,NEC,,,,.(I didn't mean to),,,but I laughed out loud when he said that. I politely told him I would love a code reference in order to be able to read this myself. He said he's gonna get back to me.
I hate that. We need a repair kit for that stuff.He cited two things, a piece of MC that got broken after we left the job.
He cited two things, a piece of MC that got broken after we left the job. (I know it wasn't like that),,,,..........
If you're present, then yes.Jeez, he's being anal. Most inspectors here would just take my work that the MC would get replaced.
I think Mivey has finally come up with the reason some of these inspectors make judgements...
I am not aware of any listing of any box in regards to securing that requires 3 screws, nails, or other fastening means.
I am curious as to how he came to this requirement. Did you ask him for a section number or other reason as to how/why?
I have a clue - combination inspectors are required to be knowledgable of and inspect building, electrical, mechanical, plumbing [and the energy] codes.
Under the mechanical code - there is a 3 screw requirement for attaching metal ducting ["shall be mechanically fastened by means of at least 3 sheet metal screws equally spaced arount the duct].
I think the problem [being a combination inspector] is there is sometimes mix up codes; at least that's been my experience.
That's my guess about the 3 screw requirement.
Got my reinspection yesterday. He never mentioned the imaginary 3rd screw. I guess he figured out over the weekend he was wrong. I could tell he wasn't NOT happy that I didn't do as he said. Oh well
