Respectfully if someone said anything that I'm about, I missed it... Sorry :\
I am considering installing a windmill generator to my main service panel, connecting to my utility using a bi-directional meter.
What does the POCO have to say about this and their requirements!
I am a little confused with the concept.
Google, Images; Using, "electrical diagram wind mill" will give you plenty of show and tell of what your thinking about doing.
My windmill generator is located approx. 500' away from my service panel and the utility transformer is approx. 150' away from the panel. The windmill inverter will match freq/voltage so I can tie directly with the utility.
See my first, two comments.
My confusion is if there is higher line resistance between the windmill and panel than the utility transformer and panel, how much of a load is drawing from the windmill as opposed to the utility considering the difference in line resistance?
There's a whole lot of what if's there! IMO. I think of a wind mill in the simple sense first as you keep the power till you can deposit it to the POCO.
Don't get me wrong it can be straight dumping of power, but the POCO is going to make you match their requirements placed on the distrubtion equipment.
I realize wire sizing is important. ...
Thats what we do, day in and day out, worry about the Wire.
I'd all so to suggest more search engine research on *.edu sites, and books addressing your exact application and repeating a big shout out to the POCO.
Sounds great, I wish I had the land and ungreen as it sounds less trees... I can bearly go Solar due to former, and the ratio payout...
But then again you haven't seen the back yard, nor I! LOL!
