? separate service, same 4x4 box
Denis
plan is to run 2 separate service circuit branches into same metal 4x4 box and install 2 recept., one for each
does one need to be isolated neutral recept.?
separate service for different rate 230.2 D
I've been up since 4:30 AM, 22 hrs+
Denis, are you asking if you can have 2 circuits in the same 4x4 box? or two circuits - one from each of two different services in the same 4x4?
Your terminology is making this hard to understand.
short answer..
other than on a MWBC, I woud think you would always isolate your neutrals on receptacles.
as far as the 4x4, you can mix circuits (other than some emergency circuits)
assuming I understood the question....
enjoy your sleep :)
