According to some training that I attended, I should only be wearing "non-conductive" eye-wear.
Does anybody know of non-conductive prescription safety glasses?
Thanks,
I don't know if they qualify as safety glasses in the intended sense, but the BC glasses issued by the military will certainly keep you from conducting with members of the opposite sex!
Who's enforcing this? I've never heard of a issue with someones glasses becoming energized. At least you have something over your eyeballs. That's better than 75% of the numb nuts out there.
the issue is they fall off your face while working on energized parts and cause an arc flash to occur.
And it has nothing to do with becoming energized, the issue is they fall off your face while working on energized parts and cause an arc flash to occur.
Normally, the wearing of eyeglasses containing exposed metal frames (or metal parts of frames) is not considered to present an electrical contact hazard. However, when the glasses have a metal type frame and the employee is working with his or her face extremely close to energized parts or when a metallic chain strap is attached to the frame for wearing around the neck, an electrical contact hazard can be present. In such cases, the standard permits the hazard to be removed by eliminating the chain and wearing either a protective face shield or appropriate safety glasses over the metal frame optical glasses.
I have to disagree based on the wording of the OSHA quote you posted.
That reads to me like OSHA is worried about the glasses contacting energized parts while on the persons face.
	But most of us ware our own prescription safety glasses with the OSHA number on the frame and there metal so i think iwire has a point ther
they also check hard hat dates .
There is no "OSHA number" on the frame, there should be Z87.1 with is referencing an ANSI standard. ANSI Z87.1 has requirements for impact and UV attenuation, but is general for all industries.
OSHA was looking for that number and allowed the metal frames because you have a laynard attached.
zog,
Remember those metal-framed submariner spectacles we were issued ship-board? Did the "hook-behind-the-ear" type temple arms substitute for the lanyard?
Those sub glasses were way better than the BC's and could actually be worn on liberty call.
Well heres OSHA SAFETY GLASSES
How we know this is 2 months ago we had a osha inspection on site and they ask to see your glasses and check the inside frame for number we passed they also check hard hat dates .
