A 750 KW emergency generator feeds a part of a building load by underground feeder. There is a 1200A circuit breaker at the generator which is about 80 Ft away from the building, and a 1200A disconnect in the main building electrical room. Can a tap be made at the disconnect output, downstream from the generator circuit breaker? Is this considered a feeder as described under NEC 240-21b? The proposed tap circuit is strictly used for redundancy in case the existing ATS fails.
