You are probably going to need to rewrite your question, because it is tremendously unclear.
'at the lifts"...what sort of lifts? Elevators? Sewage pumps?
'it has a speed'....which it? the lift, the vvvf, the motor?
etc. It is simply hard to understand what you are asking.
Here is my stab at an answer:
VVVF simply stands for 'variable voltage variable frequency', and describes a device commonly used to control an AC motor by adjusting both the voltage and frequency of the AC power supplied to that motor. The term VVVF can describe a whole range of different types of device, with vastly different capabilities.
The simplest sort of VVVF controller is an 'open loop' controller. This means that it makes no measurement of the speed of the motor, and has no feedback. The VVVF controller is simply set to a designed frequency and voltage, and hopefully the motor performs in the desired fashion. The speed versus load characteristics of a motor supplied by an open loop VVVF controller will depend upon the specific characteristics of the motor; if you supply an induction motor then the speed will vary slightly with load until the load is so great that the motor stalls.
More complex VVVF controllers have various different types of feedback loop; you might hear the terms 'sensorless vector' control, 'encoder feedback', or even 'servo control'. With suitable feedback, the controller can adjust the supply voltage and frequency so as to maintain a desired constant speed, a desired constant torque, or even a specific speed versus load curve.
The better the VVVF controller's feedback component, the more the speed versus load characteristic is set by the controller.
Hope that helps.
Jon
