frank_n
- Central NJ
I have to channel through a slab in order to feed receptacles for an island.  Since the circuit will be GFCI protected, I believe I can use Column 4 of Table 300.5.  According to the table, (under a building) has a clearance of 0.  If this is the part of the table I can use, I can run a 3/4" PVC just under the slab and sleeve it with UF.
Anyone see any problems with this?
Frank
Frank
