Not sure if this will be of help, I have used these guidelines and I have been able to successfully estimate the size of the required electrical service in a commerical building.
Lights: I used 2 Watt/ft^2
Receptacles: 6 Watt/ft^2
If you have Electric Heat: 10 Watt/ft^2
If no information on HVAC loads: 0.6 KW * 0.75
You can estimate the load for any other equipment,you can then compute.
