I was looking at a motor datasheet and noticed that it has a specification called an "Open Circuit Time Constant" listed in seconds. What is this time constant? Does this have something to do with how long it takes the motor voltage or magnetic field to decay after the voltage is removed from the motor.
It also had an X/R ratio which I believe is the ration between the reactance and resistance of the motor?
The motor also listed that it was "No-Load" tested, and it appeared that as the motor voltage was lowered the current was lowered. This is opposite what you usually see with a motor under load. Does this have something to do with the slip staying constant and therfore the rotor resistance staying constant with no load? Would't the motor frictional losses still produce a required torque on the motor?
