Joel P
- Washington Seattle area
I reciently wired a building with 12/2 fire wire and the tech that is trimming it out says that almost all of the cable ties from romex staples are too tight and causing shorts. I know for a fact that when I put them on hand tight that they did not break the insulation, but when I told this guy that he said that I dont know about fire wire and that if the tie is too tight then it can cause a short without breaking the insulation.
What is he referring to? I know that if you stretch or flatten the copper out in a wire that is a problem but I know that this is not the case with my wiring.
Any help to understand what he is even talking about would be appreciated
Joel
Joel
