sfav8r
- San Francisco Bay Area
Just curious what others think the time on this job would be. There is an existing panel that is surface mounted. It is easy to install an additional conduit from the panel up to the large attic. All rooms are accessible via the attic. This is an older home all lath and plaster with 9' ceilings. It will be vacant and mostly empty when we do the work. The average run from the panel would be about 40'
Thanks for your input.
Family Room
Remove old gas pipe mounted light fixture. Run power to existing switch location and run new switch and lighting outlet
Living Room
Install new lighting outlet and switch leg (currently no light in this room)
Bedroom 1
Rewire existing lighting outlet and switch leg (currently K&T)
Move existing outlet 3' lower on wall and ground outlet (redo in Romex)
Rewire 2 existing outlets with Romex
Bedroom 2
Add new outlet on adjacent wall
Hall bath
Remove wall sconce and associated wiring. Install new switch leg and lighting outlet in ceiling
Hall bath 2
Add 2 GFCI outlets (currently no outlets in this bathroom)
Install new light fixture
Bedroom 3
Install 4 grounded outlets (currently no outlets in this room)
Bedroom 4
Add 2 grounded outlet and remove existing wiremold
Family Room
Living Room
Bedroom 1
Bedroom 2
Hall bath
Hall bath 2
Bedroom 3
Bedroom 4
