I have a water heater and the thermostate they is different then the old one. The wires are to short to reach the terrminals. Is it o.k. to splice wire on to those down by new thermostate??? What code artical would this fall under since it's not a j-box !!!
Is this field wiring between the water heater and a forced hot water heating system? If so, I'd splice the wire somewhere out of the way and run the new wire from there.
if i am following you on this, thermostat wiring is generally class 2 wiring (article 725) which does not fall under chapter 3 wiring methods. However, there are a few exceptions that refer one to chapter 3. I am a bit confused on your explaination.
My choice....or to a junction box outside of the heater...
this is the wire from the top of the heater to the heating element !
