just curious how this works. I have seen it with double ended substations (M-T-M) configurations, but I recently saw a one-line that had a double ended substation and another derived system connect to it (basically a back-fed brkr.) connected to a generator switchboard my question is how do they set up the ground fault when the one brkr is normally open but still n&grd. connected. I believe they would use the a/b contacts on the PCB's to enable / disable the trip units GFI function and orient the CT's the correct way to sum neutral currents?? I may be totally wrong just curious..
