hot wire
- bumpass,Va
Do any of yall have the NEC on cd . Just wonding is it good or not worth the money. Im sure it takes up a lot of memory on your computer. but dont know .j ust seeing what the different oppions are on it.
I thought when CDs came out they were suppose to be cheaper. and why is it you cant reuse it i thought cd were burnt onto the disk.????
You have to install it on a computer. This requires internet verification before you can activate the copy. The way it is set up you can install it on 2 computers.
Chris
** The NFPA has changed the process for installing,
viewing, and accessing the code information. **
1 - What does this mean?
NEC customers will be permitted 2 installations of the
code onto their computers via Internet activation. For
example, if you have a desktop computer you may choose
to download the information onto that piece of equipment.
Subsequently, you can then download the information onto
your laptop.
2 - How do I activate the NEC?
Activation requires a 12-digit serial number. The number
can be found on a label affixed to the back of the CD-ROM
packaging. You will need Internet access to activate the
NEC. If you do not have Internet access, continue with the
installation. The CD will be activated via telephone, and
those instructions and phone number will be supplied to you
once the installation process is completed. Each time this
process is completed, it will be counted as one
installation/activation.
Contact information for technical assistance:
phone: 1-888-843-4461
Outside the U.S.: 1-703-392-4606
Monday-Friday 9:00AM-5:00PM EST
e-mail: support@nfpa.org
This is where I get annoyed. If I have a code book I can take it anywhere and read it. If I have the CD I should be able to put it in any computer and do the same. Stuff like this makes you want to buy stuff from a hacker. :
I have both the NEC and the NEC Handbook on CD-ROM.
That means that I have to have 2 copies of the NEC and Handbook to be able to have the NEC on CD at all the computers that I need it at.
Is there a way to copy from the 2008 NEC HB and paste while preserving the original formatting?
Whenever I paste into Word, all of the original formatting is lost.
I agree Rob,
I have a work computer, a laptop for teaching classes, a home computer, and a classroom computer at the school that I teach at.
Chris
I don't know if it would solve the 2-computer limit problem, but would the NECPlus work?
I have a CD version of the 2005 and you can at least view it on other computers without downloading the content to the hard drive. IMO this is what you should get for your money. How much does it cost the NFPA to burn a CD?
...... How much does it cost the NFPA to burn a CD?
I bet it's alot less than it costs to print those cataloges that we get a couple times a week
