PhaseShift
A friend of mine recently bought a new dryer, and noticed that the cord on the dryer only had the (2) hot wires and a neutral wire and did not include a ground wire or ground prong on the plug.  He was asking me where the ground was and why it was missing.
After thinking about this, the only thing I could come up with, is that he neutral terminal of the dryer must be bonded to the dryer frame inside the dryer. Is this usually how this setup works.
If he finds that this is indeed the case, would it be safer to remove this jumper and buy a new 4-wire/prong cord and connect the ground directly to the frame of the dryer since his outlet has a ground (EGC) coming from the panel?
I didn't think newer dryers would have this 3-wire setup with the frame bonded to the neutral. I guess for a L-G fault, the fault current will return on the neutral? Is there a chance that during normal operation L-N current can flow on the dryer frame since it is bonded to the neutral thus setting up a shock potential.
If he looks at the dryer and sees that it is not bonded inside the this would present a dangerous situation because for a L-G fault there would be no path to ground to clear fault current and this could set up a dangerous potential on the dryer frame and may cause shock or electricution?
