I agree with Jim W, if it's a receptacle then the conductor would need to be 20 amp. Other than a fixed load, how do you assure there won't be a 20 amp load on a conductor rated at 17.5 amps.
As far as Code, IMHO, 210.19(A)(1) and (A)(4) required the conductor to have an ampacity sufficient for the load served. With a 20 amp outlet, you can have a 20 amp load.
