mark32
- Currently in NJ
A customer had a wall knocked down in his high rise condo and who ever did the work broke off a piece of emt flush with the ceiling that was feeding a switch on the now non existing wall. The home owner attempted to relocate the switch to an adjacent wall and called me in to finish it. What to do now? I need to mount a box to the ceiling (He has a synthetic piece of wood that will act as a cover for the box and bx that will run from ceiling box to adjacent wall) where the emt is/was and pull a ground from the light, where the feed is. Problem, the light box is in poured concrete with emt and no separate ground, but I need to bond the ground I need for the new switch. What do you think about chiseling a small channel next to the box for one of those grounding clips or how about hitting the lug on a bonding bushing or maybe the ground screw on the fixture bar? Also, how about the flush piece of emt, all I can think of is placing a box over it, thus the need to pull a ground. Any ideas?
