file extension a3q
kellytshort
does anybody know what software is needed to open an a3q file. I had an electrician meter some stuff for me and all he did was drop off this file and I can't get a hold of him. Has anybody ever used that file type. I don't even know what kind of meter he used:mad:.
100209-1252 EST
Try opening it with NOTEPAD and see if anything is readable.
I believe notepad uses LF as the end of line delimiter. If only CR is the delimiter in the file, then you get very long lines. Maybe I have CR and LF interchanged here. If a file contains both CR and LF as the end of line delimiter, then notepad has no problem.
You can also use DEBUG to look at the raw data in a file. It is presented as HEX and ASCII.
Please check the below software, I am sure this what you need
I think this is the software and this software has this extension which is used for the following purpose;
Alpha Keys? software
Easily upgrade an A3 ALPHA? and
ALPHA Plus? meter without returning it to
the factory.
Meter function upgrades Can be added to
Power quality monitoring (PQM) A1D+, A1T+, A1K+, A1R+,
A3D, A3T, A3Q, A3K, A3R
Load profiling (LP) A1T+, A1K+, A1R+,
A3T, A3Q, A3K, A3R
Instrumentation profiling (IP) A3TL, A3QL, A3KL, A3RL
Transformer and line loss compensation (LC) A3Q, A3R
Advanced 4-quadrant metering (Adv 4Q) A3Q, A3K, A3R
www.elster.com
