100209-1710 EST
mivey:
Think!
That was an important object of one of my old profs, William G. Dow. He was a driving force behind the creation of the Upper Air Atmospheric Research Group which later became the Willow Run Laboratories and separately he was back of the creation of the Electronics Defense Group.
If you had a test question and you thought the question had a problem he would simply tell you go back and describe what you thought was wrong. It should also be noted that all our tests were on the honor system, and many were open book.
Also in EDG program review meetings when when someone was giving a presentation Dow would often ask questions that many would consider "stupid", but these questions were intended to make the presenter clarify their point because Dow realized that many in the audience were afraid to ask for a clarification.
A great deal of important work resulted from Willow Run, EDG, and Bendix Aerospace Research which was an offshoot of Willow Run. Early upper air studies, side looking radar, holography, countermeasures, signal detectability, system engineering, and many others.
For those unfamiliar with Willow Run it was an airport and B24 bomber plant built by Ford for WWII mass production of the B24. Covered about 6 square miles. The peak goal was one bomber per hour from the plant using four final assembly lines. Near the war end this goal was approximately achieved and about 2000 of these bombers per night bomber Germany. After the end of the war the University of Michigan purchased Willow Run for I believe $1.
