erickench
- Brooklyn, NY
Okay, the above table contains the percentage values for adjusting the ampacity of conductors that are bundled together at more than three conductors at a time. This table is supposedly applied to NEC Tables 400.5(A) and 400.5(B). Now both of these two tables have columns that separate the ampacity values into groups according to temperature and number of conductors. Table 400.5(B) is easy enough to use because all we have to do is determine the temperature. But Table 400.5(A) has two columns, 'A' and 'B', dividing the ampacity values according to the number of conductors. My question is this:
Which column are the adjusting factors of Table 400.5 applied to in Table 400.5(A)?
My money is on column 'A' because it's three conductors and not two. You see the NEC does not specifically say which column to apply the adjustment factors to.
