mivey
When it starts.Does that mean the fault starts at a particular time or only happens at a particular time?
So you are saying unbalanced voltage supplying a motor results in fault currents in the motor? Come on now.Listen to the kid, he knows what he is talking about.
Asymmetrical across the zero voltage reference plane. I know you know better than that. What are you driving at?Nope. Asymmetrical to what? Symmetry is formed when comparing two or more elements.
I am confused about the use of the word 'occurs'.
An diagram of the difference would help me understand this better.
I was under the impression of an example of an asymmetrical current would be a rectified half wave.
Add: Asymmetrical fault current does not include all asymmetrical current in existence. See gar's post #5.
I know. He has only talked about fault current. I have no issue with fault current other than to say that might not have been the current they were asking about.First, I did not say anything I just said listen to the kid. He did not say such a thing.
Please explain the purpose of asymmetric current controls on a motor then.Unballanced load is not consdiered an asymetrical current.
What you originally said was right. But it was not the only possible answer.ok thanks for information. what I said was it right or wrong and please advise to know the mistake.
I know. He has only talked about fault current. I have no issue with fault current other than to say that might not have been the current they were asking about.Please explain the purpose of asymmetric current controls on a motor then.
And do you think eveything you quoted is talking about the following?I found some information in IEEE Std C37.96-2000-IEEE guide for AC motor protection...
Asymmetrical and Symmetrical currents are nothing except fault currents which are balance and unbalance during any short circuit calculation.
That's just your opinion. That does not mean it matches the opinion of the test-giver. While it may not be common usage, it would not be un-heard of.In other words, all asymetrical fault currents are unbalanced, but only unbalanced fault currents are called asymetrical currents. Unbalanced currents due to the steady state or even transient load variant condition's resistance, impedance and voltage conditions are called simply unballanced but not asymetrical.
Current asymmetry limit value
Three-phase asynchronous motors respond to slight line voltage asymmetries with a higher asymmetrical current consumption. This increases the temperature in the stator and rotor winding.
The asymmetric limit value is a percent value by which the motor current may deviate in the individual phases.
The reference value for the evaluation is the maximum deviation from the average value of the three phases.
Asymmetry is defined as a deviation of more than 40 % from the average value.
Asymmetrical Fault Current to be more precise.yes, I was just telling regarding to asymmetrical current
And from the display message trouble-shooting section:...From a Siemens soft-start manual:
Message: "Current asymmetry exceeded"
Cause/Remedy: "Phase currents are asymmetric (asymmetric load). Message is output when the asymmetry is greater than the configured limit (parameter: current asymmetry limit value). Remedy: check load or change parameter value."
I took an exam unfortunately I'm not able to answer the question with Asymetric Current. The question is what is the effect of an asymetric current in a motor? Is this the same thing as In Rush Current?During starting of the motor?I checked on the net but I found no result(s)
Thank you.
God Bless...
