jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
Here is a question for all of you and your students.
Given: Simple 3 way switched circuit. The feed is at one end and the switch leg (light) is at the other end.
Both 3 ways are working and wired properly.
The homeowner replaces the 3 way at the end that feeds the light.
They forgot to mark the travellers and the 'feed' to the light.
Now it only works part of the time.
Could you over the phone and only allowing them to use a wirenut (switch not connected), help them connect the wires correctly?
