ohmhead
 - ORLANDO FLA
Well  question  i see formulas and post on power factor lots of different views on this  most give examples of there own with math use to clearly show there understanding of it  heres one question i have to ask .
Please explain this imagine a 3 phase service pick a voltage loaded on all three phases they are all resistively loaded but one has a slightly leading PF and another has a slightly lagging PF in this case by calculation or by wording which formula would be the one to correct PF to unity or closely ?
Keep in mind that maybe the VAR of opposite polarity may cancel out the other but will it in the real world if the loads switch on /off at different times is it now going to be a issue what would be the end result can a average be found meaning PF correction what is correct in this condition .
And if switched caps are used can this add to the PF problem due to charge and discharge times of these cap in a bank .
