richxtlc
- Tampa Florida
Well not a normal example or thought just a load consisting of a perfect one ohm resistor in series with a perfect infinite value capacitor if we drive this load with 1 volt RMS sine wave then the amps are 1 the watts are 1 watt the var is zero ? YES /NO
But if we drive the load with 1 volt DC at the same time what happens ?
RMS volts are now 1.414 volts the current is the same the capacitor blocks the dc and the watts are the same so VA is now 1.414 but the watts are 1 and VAR must be 1 adding dc created a reactive power ? YES /NO
So can we say a VAR is a real thing ?
No formulas needed just look at this and tell me if its wrong in thinking this way .
If I remember my theory 1 volt DC = 1 volt AC RMS, where did the 1.414 come from.
