Sierrasparky
- USA
- Electrician ,contractor
Hey anyone know what year either Electrical code or other code required smoke detectors to be interconnected in SF dwelling?
Won't a gaggle of chirping detectors give it away?Myself I also prefer to connect the smoke circuit with a prominent lighting circuit, so if the flip off the breaker they will be missing the lights.
This is a building code issue and not an NEC one. I have no idea when the interconnection was required. My bet is the 90'sHey anyone know what year either Electrical code or other code required smoke detectors to be interconnected in SF dwelling?
Had inspector flag me for not interconnecting fire alarms on both sides of a duplex apartment . He said if there is fire on one side the other tennent needs to know. I said fine, which side do you want to supply the power, the one that has no service now or the other one. He stomped off mad and said leave it like it is.
I'm not sure but would NEC 2008 210.25 A and B have anything to do with that?? If they connect to a 'central alarm, or signal communications. If not, then maybe this article doesn't apply.
