hillbilly1
- North Georgia mountains
- Owner/electrical contractor
I found out something yesterday, Energy management modems do not like Voip! Installed an energy management power monitor at a big box store, the modem shares a line with a fax machine, the modem can only be accessed in a predetermined time frame, so it does not conflict with the fax machine. The modem would connect sometimes, but the majority of times would not, or would disconnect shortly after connecting. Fax machine works fine, no noise on line, after four hours, the manufacture decided that the modem must be bad. Came back and replaced the modem, still had the same problem. Manufacture checked settings and firmware, and could not find any problems. This led me to believe there was a problem on the telco end. Went all the way back to the demarc at the other end of the building, and found that number did not exsist at the demarc! Got to digging, and found phone line originated from a computer. Voip! Hi jacked an actual hard wired line, the modem started working perfectly! Apparently Voip is not good for faster speeds like a computer modem. Works fine for fax lines though.
