I have an application where only 120/208 volt is available in the building, and the Contractor has supplied a 120/240 volt load center for a standby generator (aux equipment). Are there any code violations associated if we feed the load center with a 208 volt single phase feed and ALL loads connected to the 240 volt single phase load center are either 120 v or 208 volts single phase?
