Buck Parrish said:You will want to have the poco cut the power first.
George Stolz said:Agreed.......
There ain't a (small) fuse if you hit those lines. Caution (safety, safety, safety) is called for.
Sure there is! It's called the service entrance conductor......... short it out long enough and it becomes a 'fusible link'!
Actually, I like to say, "There's nothing between you and Hoover Dam."
And you (if you're the dope cutting the SEC) may be purchasing all of the equipment damaged, and possibly other litigious damages and fines from the POCO or AHJ. I like to say - The "fuse" might be a 30KVA transformer, $10K fine and your neighbors house, maybe your own too - or all of the above.Sure there is! It's called the service entrance conductor......... short it out long enough and it becomes a 'fusible link'!
A while back (decade) a GC here decided to move a service by taking it off the wall and shifting it over - the mast snapped, shorted, as the lines melted together they eventually fell onto the neighbors front steps - igniting them into a small fire - which the fire dept promtly put out, and used pick axes to make sure they were out. The neutral must have been the first to go - since every electrical device in the house he intially did this to let the smoke out - and along with most of the neighbors - every house on that transformer. When I got there - to put the new service back on the original building people were still finding things to add to the tally... Cars with molten plastic and metal dripped on them from above - appliances, TV's and the POCO decided the transformer was damaged in this and needed to be replaced. That GC got to pay for all of it... No one wants to be that guy.
Wow all these fancy tricks and all this time I was just really careful with a hacksaw.![]()
Is that one of those things that hold a saw blade in a frame with a wooden handle? It's manual, right? You have to manually push it back and forth? Kinda like a Sawzall but it's somehow powered by the muscles in your arm?
I've heard of those things. Don't recall seeing one, though.![]()
You young kids an all your fancy tools. Bet you never had to use a yankee either.
When I was a kid we didn't even have electricity, we had to drill out the studs with a sharp rock.![]()
It was turned off for several days - when I showed up a lynch mob was forming, and I had to talk quick to explain that I had nothing to do with the big fiasco the CG did.But, the power was still turned off, wasn't it?Mission acomplished, then.![]()
Around here, only the spoiled kids had sharp rocks.You young kids an all your fancy tools. Bet you never had to use a yankee either.
Mine too. In those days, I had a set of hammer drills, and the busted knuckles to go with it.Who's young? Just so you know, my first hammer drill was one of these:
"We were so poor, the whole family had to share one pair of shoes."Around here, only the spoiled kids had sharp rocks.
