Puck light Idenification help 12v 10a
Thought I would see if anyone recognizes these. My lighting vendors only suggest Nora. I need to get more of the same for appearance as well as application issues (custom truck trailer). These were installed in a Featherlight Trailer in '06 (Featherlite was no help).
Thanks again everyone!
-Jeff
Jeff, Try entering in all that foreign text from the tag into http:translate.google.com and see if that helps, German, I think???
I need them to match as this is a show trailer, plus the heat/insulation clearance issue (these are plastic on the sides).
Yes, It's German, mostly UL type documentation I think.
I was hoping someone would recognize the manufacturer.
Thanks guys
They are so cheap at the Home Depot- just change them all out. The one at the Big Box stores are also either white plastic or metal- they look very similar.
Good luck trying to match them.
A search on the UL site for the file number (E145927) comes up with no matches. Normally this type of search would come up with the manufacturer's name.
