250 watt MH
Have a 250w metal halide lamp that appears to "flicker" incredibly fast. It's in an outdoor wall pack and the area it's responsible for lighting is still well lit. Looking directly up at the fixture is when the flicker is noticable. Any ideas as to why this would be occurring?
thanks in advance
Vibration of the lamp?
I guess that's possible.
But
building is empty (at night)...no machinery, etc in building causing vibration
luminaire is securely secured to (secure) building;)
socket is properly secured to luminaire
Lamp is securely installed
checked all these items
(OK, I didn't attempt to move the building).
what would be causing this vibration?
any other thoughts or experiences with this type of circumstance?
I'd probably just replace lamp first, then the ballast too if the problem didn't go away. I'm assuming all wiring connections are tight and the voltage isn't fluctuating.
Simple explanation is a bad lamp. Every now and then one will slip thru production, ever had a bolt with no threads? The lamp mfg process is automated, they make thousands,
But its an odd problem. Post back with what you find.
The plates in the xfmr are loose and probably vibrating the filament. I've heard MH's on metal buildings that literally sound like an air chisel hitting the tin. Yours is probably vibrating just enough to shake filament
