I wanted to figure out how to calculate the voltage drop to a motor that is on the output of a VFD, for the motor operating at low speeds.
Lets say that we have a motor/vfd combination that at full speed and full curerent has aprox a 3-5% voltage drop which is usually what is deemed as acceptable. We know that this voltage drop will be a function of bus voltage, cable size, motor current, and cable distance.
What happens however when the VFD is operating at low speeds and thus the voltage output from the drive is reduced to maintain a constant V/Hz? Lets also assume that we are dealing with a constant torque load, so it is possible that full current is needed at low speeds in order to produce full torque. Now since we have the same size cable, the same distance, and the same current, we will still have the same amount of voltage dropped across the cable, however this drop will now be a larger portion of the output voltage to the motor.
So this same voltage drop which may have been 3-5% of the output voltage at full speed and full drive output voltage (bus voltage) will now be a larger % of the reduced drive output voltage at low speeds.
Is this increased % voltage drop something to be concerned about at low speeds? Can this reduce the V/Hz at the motor and cause issues? Is this why drives have voltage boosts at low speeds?
