I understand what 110.14(c) says. It says that if its under a 100 amps , I can use a higher temperature rated conductor(THHN), as long as I size it with the 60c column in table 310.16. For example, I have a 50A range receptacle with 60c terminals. If I use THHN, you go to 310.16 and size that wire according to the 60c column because of the terminals, and its a 6 AWG.
Now my question is, what if that receptacle was located in an ambient temperature 100F? Which correction factor column at the bottom of 310.16 would I use, the 90c because of the THHN or 60c because of the terminals?
