jetlag
- Eatonton, Georgia
I have a location wanting a service pole for a mobile home installed . It is considered farm land for agricultural use so code shows a clearance of 18 ft above ground for the service drop , and the poco has told owner that is clearance they want. I dont see how this applies up in the yard around the mobile home where there is grass planted. If I use a 20 ft pole 4 ft in ground it will be 16 ft on top where they attach the drop . poco pole is much taller and by the time the drop leaves the grassed area the drop will be over 20 ft. The reason I use 20 ft poles is that is the longest they sell around here unless you but a 40 ft one about 10" dia from the poco. Also 20 ft is the longest I can deliver on my service trailer. Ive seen lots of homes in the middle of farm land with a regular 12 ft high service mast on the house. From there they go to a tall poco pole outside of the yard area.
