- NE Nebraska
- EC
don't know how far you are running this line but have you considered both cost difference and other advantages of running underground. Clearances will definately not be a problem.
A simple solution that I can see is attatching a stick of 2 1\2" rigid conduit as a mast bolted to ouldof pole gives you annother 6 ft clearance bringing you to 20' to weathehead. Point of attatchment 6-12 inches below weatherhead giving you 19-19.5' clearance. About 150$ in material not a big deal easy fix.
I just didnt think your idea made much sence , but I was joking, sorry
The OP can't except the answers that have been given & No I wouldn't be hanging some piece of Steel to meet the requirements!
I know that professionally they are making the Client handle their own business! ( A real BIG Flair to ME! )
If one doesn't meet the POCO's requirements, nothing else needs to be said, just JMHAO!
...., and the poco has told owner that is clearance they want. I dont see how this applies up in the yard around the mobile home where there is grass planted....
I forgot to mention the yard area is fenced in about 100 x 100 ft. It seems like a big overkill to have 18 ft service drop clearance in there. I told the owner to recheck with the inspector and poco and call me back. If he says they want the 18 ft I will tell him to pay the poco to set the pole, I think they charge 375.00 , then I will come and build the service.
Check metal suppliers in your area for prices on a 24 foot metal pole, 4 x 4 or 6 x 6. I priced stuff awhile back for a possible project and I think metal was sometimes cheaper, and easier to get. Worth a try.
I doubt the poco will hit that , they are used for stadium and parking lot lights with underground power. But I will check
