This scenario is driven by building code and the subsequent question is compliance with article 225.
For a specific construction type a building is limited to a maximum square footage and height. If fire walls are utilized the appearance would be a contigous building that is actually multiple buildings under one roof.
For a large building, such as a school, the designer has chosen to separate the allowable square footage areas by fire walls. There is an MDP that feeds the entire school in one of the areas and then multiple feeders routed to and through the other areas to serve various panelboards and loads from the MDP.
I understand that I actually have "separate buildings" although the appearance is that of one building. Does anyone have any suggestions, short of a complete re-design of the electrical system, to comply with the NEC with particular respect to 225?
Thanks, Pete
Thanks, Pete
