Considering the likelihood of someone actually doing this, I felt it was not necessary to note suchYes, but it should be noted that the Delta-source neutral is not at the same potential as the Wye-load neutral, nor should they be connected.
Actually, my comment is aimed toward those who consider re-supplying an existing Delta panel from a Wye source.Considering the likelihood of someone actually doing this, I felt it was not necessary to note such![]()
It is. It is also feet for the tripod (like rubber shoes, pivoting shoes, etc). There is also a shoe when the tripod has a quick-release plate/shoe adapter. See the features here:I thought the shoe is where the flash mounts.
I just finished 4 chapters of transformers at school and i am still very confused. I'm in a class where the much younger students and the teacher have the common interest of getting out of class 2 hours early which means asking questions in class is pretty much out. So i'm hoping to get some help here.
Sorry to hear that, I did training for 10 years and this seems to be the way a lot of training is done. 1st question was always what time will we be done? I never let them out early, in fact I would sometimes assign homework. They were not happy but by the end of the course they actually learned something.
Actually.
"They mostly come out at night . . . mostly." ~ Newt in Aliens
Well thanks, I'm tinking hard about going into 3rd year. I think i'm going to try to sit in on some third year classes this year and see if the instructors are actually trying to teach something.
Regarding Delta and Wye. Thanks for the replies, i'm still trying to digest.![]()
This stuff is hard.
Need to note your #2 is only true of balanced loads....
Delta (standard, not high leg):
1. Voltage line to line = Phase Voltage
2. Line Current = 1.73 x Phase Current
New mental image for a wye system:
Let's compare a 120/240v winding like the pedals of a bicycle, with the two pedals at the usual 180 degrees apart, with the axle of the crank as the center tap. Let's say the length of each pedal's arm is 120v long, so the pedal-to-pedal distance is 240v.
Okay, here 'tis:
We still have three legs, but instead of a three-armed pedal crank setup, let's say our bike is a velocipede (and no, it's not a dinosaur) with three pedals bolted to the front wheel.
Nah! Same bicycle with planetary geared hubSo what would a zig-zag transformer for grounding a delta system look like?
Would this be a tandem tri-pedal bicycle?
Who sits in front and steers?
Kevin, here's how to visualize why it's 100%, or equal to the other two lines (if they're equal.) Start with a balanced load; zero neutral current, right?
Now, reduce one line by one amp, and the neutral current will jump up that same one amp. Keep going until that line has zero current. See it now?
Your calculation is not what Larry said, which was start with a balance load... i.e. A phase would also be 10.Larry, I referring to a 3 phase 208 / 120 volt transformer. Your rationale is true to a single phase 240 / 120 volt transformer. Here is the answer to your example for a 3 phase system.
Use the 3 phase neutral formula and omit the A phase. N=sqrt B^2 + C^2 - BC.
As was I. My example was to explain why you have what you used as the starting point:Larry, I referring to a 3 phase 208 / 120 volt transformer.
In other words, why the neutral of two lines is a CCC when the source is a 3ph Y.phase currents
A B C N (grounded point)
0 10 10 10
