I am not very familiar with open delta connections, but I have recently ran into quite a few of these systems. I am a 21P in the Army, and am currently on a training mission for doing power assements to provide back-up power generation during natural diseasters.
Most of the open-delta configurations I have come across have been at lift stations, (sewer pumps) which are usually located out in the country away from three-phase lines.
I understand why they use the open-delta as it is much cheaper to run single phase and get three phase power using an open-delta connection, but I am a little confused as the stuff I have researched has used two different numbers that reduce the output of the transformers when wired in open-delta.
I mostly see that the output when using two transformers is reduced by 57.7%, but I have also seen a few times where when the open-delta is by design, and a winding not failing the output is reduced by 87%.
Sorry for the long post, but if someone could explain this, or provide a link it would be much appreciated.
Thanks a lot!
Thanks a lot!
