brother
You're seriously suggesting to install spark rings, longer 6/32s, and sweep mulch in against the sides of the GFI and use it as a "finished" surface?
110.27 is called "guarding of live parts". That limits it's subsections to "live parts".
How is this much different than mounting a receptacle face up on a ledge?
Like I said, I believe its not just limited that heading, and even then its still in context what we are talking about, the live parts inside the receptacle.[ And it says 'likely' to be exposed to damage. This is a 'judgement call of the AHJ.
I believe like someone else had pointed out, that sweeping mulch (broken wood bits),dust etc. over the top of a receptacle without a cover the live parts inside the receptacle are likely to become damage, a potenial fire hazard.
All the other floor receptacles Ive seen had the floor covers for it, and when it was in use it NEVER had mulch or any other stuff over top of it. Common Sense does come into play for some people.
I know most people want to limit 110.27 to the 'big' gear especially when it mentions vaults, rooms partitions etc.. Or on balconys. But (B) in my opinion gives the AHJ permission to tag this install.
Like I said, the article was a stretch, but I believe common sense should come into play here.You're seriously suggesting to install spark rings, longer 6/32s, and sweep mulch in against the sides of the GFI and use it as a "finished" surface?
