e57
- San Francisco, CA
So - got a puny ('no one else wants it') job... Hanging a swagged crystal chandelier of ~40 pounds from a nearby box to over a dinging room table that would not look good at my house.
I've worked in the building before - for a former employer - and the max drilling in the post tension concrete ceiling is 1 1/8" - which is just fine for mono-rail track with multiple supports on the "provided" plastic anchors. (if they were not provide - I would not use them.)
Initially - I was thinking of just a single expansion bolt or drop anchor - but if it fails - I'm screwed... (the fixture is worth more than the job, and the table equally so.) The second thoughts are two/a few of the same, or tap cons spaced under a false canopy....
What say you?
What say you?
