406.11 Tamper-Resistant Receptacles in Dwelling Units.
In all areas specified in 210.52, all 125-volt, 15- and 20-ampere receptacles shall be listed tamper-resistant receptacles.
What do you do with your existing stock?I have at least 75 outlets and gfi's and 20 decora receptacles.
Send 'em to me; we're still on the '05.What do you do with your existing stock?I have at least 75 outlets and gfi's and 20 decora receptacles.
Are non-TR receps required to be TR receps when replaced?
I think that they SHOULD but that is not how I read:
Ohio (IRC based):
115.2 Maintenance.
So I think that non TR recpts could be used.
115.4 Additions and alterations.
Now for additions or alterations then yes.
Where are TR recepticles required?
NFPA says new construction and renovations would changing an existing outlet fall under renovations?
In dwelling units, yesAre outside WR GFI's required to be TR?
