weressl
Esteemed Member
I understand that 2% of 240 is the same as 1% of 120.
When I run calculations I get a 2.5v drop. When somebody needs that in terms of % drop, do I use 240v, or 120v?
It is a 120/240v circuit.
But that is NOT what you said in the original post. You said it is a 240V cisruit. One presume that it is a 2 pole breaker. Or are you mixing 120 and 240V loads on the same circuit?
