D doverelect Member Mar 12, 2010 #1 what if any are the requirements for this. This is the first time I have seen in a job spec.
raider1 Senior Member Staff member Location Logan, Utah Mar 12, 2010 #2 Welcome to the forum. Could you give us a little more information as to what the seismic electrical installation is in regards too? The building codes have specific requirements for seismic securing and supporting of lay in fixtures in suspended ceilings in high seismic areas. Chris
billsnuff Senior Member Location East of 480sparky Mar 12, 2010 #3 guides for lighting guides for lighting http://www.seismicceilings.com/applicationsGuideC.jsp
W wireguru Senior Member Mar 12, 2010 #4 could also refer to anchoring of switchgear, additional bracing of pipe racks to prevent horizontal movement, and other such things.
D doverelect Member Mar 12, 2010 #5 seismic electrical installation this is in the elect. spec for a remodel of a car dealership to be done@ a suburb of Boston
C charlietuna Senior Member Mar 12, 2010 #6 Pertains to making the switchgear and generator "earthquake proof" . Have to pour steel angle iron into housekeeping pads with bolts to prevent the equipment from jumping around?
Sierrasparky Senior Member Location USA Occupation Electrician ,contractor Mar 12, 2010 #7 What portion of the Electrical installation is the spec reffering to? As others have stated : 1) Seismic support of Lay-in fixtures. Additional support wires and or screws 2) Seismic hold down and support for Switchgear Bolts into concrete or other structure rated for the use 3) Seismic support of High/ low bay fixtures or similar Luminairs Extra aircraft hang wire or similar 4) seismic support of Pipe racks or cable trays' usually every so many feet a Diagonal brace to rack or Tray to minimize lateral movement There are many variables depending on Locale. Should request RFI from Engineer.
